UPDATE: Rear lit 'CAMARO' Lettering w/pics
wow looks good:bow: :bow:
just out of curiosity, how did you do that? was it easy to cut? is the wire for the light spliced to something? any help would be appreciated. thanks:bow: |
The almighty Dremel... just pulled the panal off, and went to work. I used two neon tubes from autozone, green of course, and they are just on a simple switch that controls the power side, the wires are grounded at the back where the hatch... latch are grounded. (remote ground)
It took about 1 hour per letter, wanted to get it right and it was the only panel I had. Had a piece of plexic cut that wa sa bout 2" by 24" and plastic welded it. The middle of the A's and the O I just glued onto the plexi. I will go back and do really good job with fiberglass and sandpaper when I repaint the car. Laterz |
