Update on the project...powdercoating and other goodies
i have posted some previous pics of my painted engine bay and some powdercoated parts....well here is a few more pics with the description under the pic.
Pic of the freshly pulled hamster wheel.
My cradle and suspension. its actually farther along than this. will update the pic tomorrow. everything is powdercoated, and poly mounts
New short block being assembled.
Coated oil pan mounts and stainless bolts..
Ac delco Opti and Msd cap
Powdercoated Accessory Bracket..
Powdercoated Water Pump Housing and CSR EWP Stainless bolts again
other side of engine.
Powdercoated Valve Covers
Assembled Suspension
ill take some more pics tomorrow and get them up. pics of the engine bay, tranny tunnel and undercarriage. i also will be installing magnaflow catback umi sub frame connectors and lakewood lower control arms. my intake and throttle body are also powdercoated when i get them back this week ill post pics....sorry some of them are a lil blurry...
Hmm
I'm pretty meticulous when I assemble an engine, and on the intake I will use plenty of right stuff gasket maker. That stuff is AWESOME! I'm hoping that with enough patience and precaution I shouldn't see any leaks for quite a While....Thanks for all the compliments guys!
Looks GREAT!!! I see one problem you'll run into though with powdercoating your accessory bracket. The alternator uses it as a ground, so with it powdercoated, your car will not charge. This happened on a friend's car that also powdercoated his bracket. He ended up running a ground strap from the lower alternator bolt to the block, but if your motor is still out of the car, take the bracket off and take the powdercoating off where the bracket meats the block by the bolts (to create a ground to the block) and also where the alternator sits in the bracket by the bolts.
looks great stay on it and pay attention to details and it should come out amazing. when i put my engine in i cleaned everything good but nothing like yours. now i regret not taking the time to paint powdercoat and polish more.
i really appreciate all of the compliments. it has all been very very worth it. thanks for the heads up about the alt! ill get some pics up tomorrow, i PROMISE. ive been so busy the last two days i havent even had time to work on the car.
I have a question about the water pump.
When you had it coated was there and seal or other parts that need to be removed to coat?
Thanks Mike Fitzgerald.
PS
Your Project is looking great!!
PS
