Trim Piece on the Door
My passenger side doors trim piece is starting to come off. It is beginning to peel off from the front of the door and it looks pretty bad. I am looking to replace/fix it, but I don't have any idea as to how to do it.
http://i126.photobucket.com/albums/p...TrimPiece3.jpg I'm guessing that I would have to just totally replace it because it even started to affect it more towards the middle of the trim piece. I called the dealer to check them out, they are almost $60 (I would have to paint it). If I did have to replace it, is there a chance that I could pull one off of another Camaro and have it still be usable? |
no they come painted just need to make sure you remove all of the tape from the door before you put the new peice on
better solution, take all that crap off and save some money anddddddddddddddddddddddddd your car will look better
Originally Posted by chet
(Post 4733872)
Originally Posted by davidz28guy
(Post 4733921)
It's so easy to do,just pull those suckers off and give the area a good polish. |
Originally Posted by MARKTHOMASBRAND
(Post 4734460)
I totally agree :D .
That does look pretty good. I'll have to think about just ripping them all off. What stuff would you recommend I use to polish the area after?
Originally Posted by 90tealindy
(Post 4734584)
(Post 4734611)
I just used regular car polish/wax.You will be able to remove most of the gunk with your thumb or finger,it sort of just rolls off.
(Post 4735067)
Sweet. I'll to give it a go next week. Thanks for all the info!
word, a heat gun (or blow dryer) and some goo-gone and a wax and youre good to go :D
http://i93.photobucket.com/albums/l4...H/100_0219.jpg vs http://i93.photobucket.com/albums/l4...IMG_0059-2.jpg |
Well I began to work on getting the one off of my door today. I had to stop for now, but it came off really easily. I can't say the same for the adhesive crap. I got most of that stuff off now, but there is still a little bit left on there that I can't seem to get off. And apparently when the previous owner "fixed" it, they scratched it up pretty good under the piece. The scratches aren't too bad, but definitely noticeable. What can I do about the scratches?
Before:
http://memimage.cardomain.net/member...0_107_full.jpg After: http://memimage.cardomain.net/member...0_108_full.jpg Its much nicer w/out that crap on there IMHO....good luck! |
Originally Posted by stroked 383
(Post 4749760)
Before:
