Shift boot bracket replacement now available!
Everyone,
we have finally solved the problem encountered in most 93-97 and 98-02 Camaros and Firebirds. The stock mounting bracket for the shift boot is plastic and it's very brittle, hence it's shattered on most cars anyway. The replacement part is NOT available from the factory! For a mere $19 extra, you will get a METAL REPLACEMENT BRACKET from us! The bracket will fit just like stock. The shift boot needs to be slightly modified at the bottom to work seamlessly with the aftermarket bracket we provide. If you opt for the bracket in addition to your shift boot, you will get the modified shift boot that will work with the bracket, of course. So, we're a one-stop shop to solve all your shift boot woes. :) Here's a link to our other thread on this forum: http://web.camaross.com/forums/showthread.php?t=430485 Here's what the bracket looks like: http://www.redlinegoods.com/images/F...bracket-01.jpg http://www.redlinegoods.com/images/F...bracket-02.jpg Enjoy! Maciek |
We've received a lot of inquiries regarding the possibility of purchasing the brackets separately from the shift boots. So, as of recently they are available on our website:
Camaro: 97.5+ -> http://www.redlinegoods.com/order.sh...aro9802bracket 93-97 -> http://www.redlinegoods.com/order.sh...aro9397bracket Firebird 97.5+ -> http://www.redlinegoods.com/order.sh...ird9802bracket 93-97 -> http://www.redlinegoods.com/order.sh...ird9397bracket Take care, Maciek |
