round headlight conversion
im very interested in doing the round headlamp conversion. any kits availible? or what parts would be needed.. also is it possible to stay under $300?
Edited - The post was just recently brought current - check it out here. Sam95Z........ (thread starter) is the guy who is making the guide and has a sort of picture guide. I think it runs right at $300 to do as well. That thread should answer just about all of your questions.
But you must beware - before doing this mod you have to shorten your sig length by about 10 lines or it won't work. :) |
u mean the ls1 headlights?????
Originally posted by 94BlackBowtie Edited - The post was just recently brought current - check it out here. Sam95Z........ (thread starter) is the guy who is making the guide and has a sort of picture guide. I think it runs right at $300 to do as well. That thread should answer just about all of your questions. But you must beware - before doing this mod you have to shorten your sig length by about 10 lines or it won't work. :) Hella 90mm Conversion Sam |
Every so often you'll see a "kit" pop up on eBay. Here is a write-up on one method...
http://www.bfranker.badz28.com/94Z/piaa.htm And, yeah, your sig is way too big... so, from the moderator, please make an effort to shorten it a bit. While it isn't enforced unless extremely violated, we ask people to keep the sig to around 5 lines. 6 or 7 lines will typically be not noticed but when you get up to 10 or 20 then it is hard to look the other way :D |
