Rear seat removal
Pretty much what the title states. I haven't looked into it much, but I know how to get the back to fold down, how do I take it out? What about the bottom?
each lower seat has a 13mm bolt at the very middle of the bottom front part of it and then they just come right out. once you remove those then you can see the 2 13 mm bolts on the bottom of the upper seat part. there is one on each side down on the bottom. also there are 4 T30 torx bolts that hold the seatbelt brackets to the back of the top seat section. it's pretty easy to remove them. i took mine out last february for reupholstering.
Originally Posted by 1995blackttopta
(Post 6122443)
Thanks |
