power antenna
i have a 99 camaro and i am wondering if i can take a power antenna from a firebird or trans am and put it in my camaro if anyone has done this is it extremely hard and what all parts would i have to have to do this
thanks mark |
Re: power antenna
you can buy power antenna kits at most auto stores, no need to get one from an old car,that way it would a universal part and you would know it would work. I think they work off of 3 wires, 1. a constant 12v source, 2. radio power line, and 3. ground.
in that case it would be ideal to just splice 2 wires from a constant 12v and put one on a switch, that way you could control the antenna yourself. although I do beleive the SS camaros did some with power antennas for a few years, the nice thing about the GM ones is that they were all black instead of chrome, but i think you can get black universal fit ones too. |
Re: power antenna
The Camaros and Firebirds are so close that the GM Service Manual covers both in one. The standard method of doing this is to get a Firebird antenna and put it in your Camaro. It works just fine. As stated there are three connections plus the coax. Power, signal(radio on), and ground.
If you have a cd player in the trunk you can access all three connection off it, which makes the wiring shorter and easier. |
