Painting rotors, calipers, LCA's
I bought some high temp 900* black paint for my rotors and calipers. I plan to sandblast them first. Then paint them with the high temp paint. My question is: Is it ok to use primer and clear coat or will they just flake off from the heat? Do they make a high temp primer or clear coat?
My next question is. What kind of black paint should I use for my LCA's. I don't want it to chip off and rust in like a month. |
they make high temp clear. im not sure about primer but i thought ive heard about it. i would use some kind of chip guard for the LCA's. i think they make it in black and clear so thats the best of both worlds. maybe someone else will let you know about the primer.
I used charcoal grille paint from home depot as primer it's pretty much the same
