Is a new air dam needed for an F-1 body kit
Old 09-10-2002, 08:51 PM
jeff94z28's Avatar
Post Is a new air dam needed for an F-1 body kit
Just like the subject says. Is a new air dam needed with the Front F-1 piece. It has a lot of holes and isnt very low to the ground. The few websites I have seen it on dont say anything about it in the kit or in the single just the front piece. The front is the only part I want, and theres no option below for the air dam. I dont know if its included in the cut and just not for separate retail or what.
http://www.sounddomain.com/id/jeff94z28
Borla Exhuast, K&N filter, Jamex Strut bar, 160 stat, Hedmen High flow Cat, BMR Lowering Springs, Painted A/C vents/Fake Scoops, 2 12inch MTX subs, Rear Fill in Lettering.
jeff94z28 is offline
Old 09-14-2002, 07:29 AM
TravisWsparks2's Avatar
Post
If it doesnt come with one then you will need another one. Ive heard of peoples car overheating if they dont put on anther air dam when puting on ground effects
TravisWsparks2 is offline
Old 09-14-2002, 11:59 AM
bigdreamZ's Avatar
Post
If you are taking about this kit that was a factory option, then no you do not need an aftermarket airdam.
bigdreamZ is offline
Old 09-14-2002, 02:47 PM
jeff94z28's Avatar
Post
Yea thats the kit I didnt know if the factory changed the air dam or what. So Id figure Ill be safe and ask. Thanks
Old 09-15-2002, 01:36 PM
ollie-99's Avatar
im not sure about that body kit and i got the wings west body kit and i had to purcahse one from them....
goto there website: www.wingswest.com
hope that helps...
ollie-99 is offline
Old 09-16-2002, 07:10 PM
superal's Avatar
If it has holes in the front, your obviously not going to need a bigger air dam. Air can flow to the stock air dam easily.
superal is offline
Old 09-16-2002, 09:40 PM
sandmanljs's Avatar
What about the Xenon and DG Motorsports body kits. Do these require a larger air dam as well. Both look like the really wouldnt change the airflow that much, but im probably wrong.
THanks
sandmanljs is offline
rockync7
01-01-2015 05:10 AM
CARiD
12-26-2014 04:20 AM
07-04-2005 05:00 PM
RedLineRev
01-23-2003 03:51 PM
ezcheeze15
08-08-2002 12:27 AM
Quick Reply: Is a new air dam needed for an F-1 body kit
