Looking for pics of 93-97 convert. camaro with stock rs ground effects
Old 10-18-2009, 04:22 PM
SMO Q's Avatar
If any one knows a sight, or has a polo green RS preferably w/tan top, and stock ground effects, Id like to see what they look like on that color car. Im considering these F-1 Ground effects, wings west has bought the mold from GM and the prices have come way down.
SMO Q is offline
Old 10-19-2009, 02:43 AM
fbodyrs96's Avatar
it's not green but it has everything else..
fbodyrs96 is offline
Old 10-19-2009, 09:07 PM
SMO Q's Avatar
thanks. have you ever had any problems with them? bottoming out? coming loose? if you pull into a parking spot and put the front end over those cement guards (I dont know what they are called? they are yellow sometimes) will it hit them? hows speed bump/curb clearance? most importantly can you get a normal floor jack under them behind the front wheel? I think they got it right at gm. those are the best looking GFX for camaros on the market
SMO Q is offline
Old 10-20-2009, 12:18 AM
Brangeta's Avatar
I think they'll definitely hit and scrape on curbs, which is why a lot of Camaros you see for sale have ground effects but are missing the front piece.
Brangeta is offline
Old 10-20-2009, 02:30 AM
fbodyrs96's Avatar
if you take it easy it's no big deal you just have to pay more attention to those things, and it will clear some of those cement blocks but not all, I just avoid pulling up that close, why take the chance. I've never had a problem with speed bumps yet and yes most floor jacks will fit but it's tight, I have a low profile one...one more thing if you use ramps you will need extensions, I use 2 4ft 2x10, that gives me enough clearance to get on the ramps..
Old 10-20-2009, 10:12 AM
Z28SORR's Avatar
Also with the ground effects you need the extended air dam, and that hits EVERYTHING!
Z28SORR is offline
Old 10-21-2009, 05:32 PM
SMO Q's Avatar
I thought thats what those holes were for in the front of the stock gfx, for air to the air dam. well, any way mine is already probably as sharp as a knife, its all ground down from pulling into steep driveways.
SMO Q is offline
Old 10-21-2009, 05:35 PM
SMO Q's Avatar
fbodyrs96: your car is fricken beautiful.
SMO Q is offline
Old 10-21-2009, 08:46 PM
fbodyrs96's Avatar
Thanks man...
LT14LIFE
02-09-2015 09:35 PM
rockync7
01-01-2015 05:10 AM
MJ_Z28
08-07-2002 07:15 PM
5.7L 00 SS
08-06-2002 07:01 AM
5.7L 00 SS
08-04-2002 06:26 PM
Quick Reply: Looking for pics of 93-97 convert. camaro with stock rs ground effects
