Justout of curiousity,would these fit ok??
Ive read that as long as the backspacing and wheel width are right, bmw wheels will fit camaros. I found these wheels on ebay, and I think the would look awesome on camaros. With an 8.5" wide wheel, is +18mm backspacing ok or no??
:eek: $2000 for replicas!! They do look good, but that is alot.
Oh yeah, I am not sure if they would fit. |
They're only 1200. Besides, even though they are replicas, they are 2 piece wheels, which are more expensive than 1 pc.
Re: Justout of curiousity,would these fit ok??
Originally posted by White30th ...is +18mm backspacing ok or no?? You need to just buy my wheels.... ;) http://cgi.ebay.com/ebaymotors/ws/eB...tem=1874824621 |
Those are sweet rims...
Originally posted by pu12en12g Those are sweet rims... |
Originally posted by White30th I know, and someone posted this pic of a formula with wheels that look exactly like those. If anyone knows where I could get these wheels in the correct spacing let me know. http://www.ayresweb.com/wheelclose.jpg It appears to me they are using a wheel spacer/adapter like you can get at http://www.skulte.com/adapters.html That looks like the exact wheel you are talking about. They just used a bolt on spacer to make the backspacing correct. I did the exact same thing by using some FWD rims on a 96 GMC pickup. -Shawn |
Yeah, I see the spacers. What size spacers would be needed and would the be needed for the front to?
Originally posted by White30th Yeah, I see the spacers. What size spacers would be needed and would the be needed for the front to? If I were guessing though, I would guess a 1.5" spacer would do it. That would put you at 55mm offset. BUT, you still need to ask for the backspacing to get the exact thickness spacer you would need. And yes, you would need spacers on all four wheels. -Shawn |
Originally posted by TA25th I cropped the rear wheel in that pic and enlarged it... http://www.ayresweb.com/wheelclose.jpg It appears to me they are using a wheel spacer/adapter like you can get at http://www.skulte.com/adapters.html That looks like the exact wheel you are talking about. They just used a bolt on spacer to make the backspacing correct. I did the exact same thing by using some FWD rims on a 96 GMC pickup. -Shawn |
Originally posted by 89irocz23 I believe ROH makes a wheel similar to that. |
