HID headlights
Is there an HID kit available for the 1993-1997 Camaro?
No unfortantely there isn't because of the headlight assemblys. They can't support the HID bulb so therefore no HID headlights for 93-97s
Technically, no. You won't find any made specifically for the LT1 but you can use any 9006 HID kit.
With that said: Will it fit? Yes, with some modifications. Will it be street legal? Technically no since they aren't D.O.T approved. Will it be better than OEM lighting? Yes. Will it compare to factory HID w/projectors? No, not even close. So...consider if it is worth it for you. Until I can fab some projectors, I'm living with HIDs in the OEM housings. |
