Door panel Screw sizes; triangle and handle bezel
Anyone know those sizes? The little upper triangles and the handle bezel, each have single little screws.
Also, is the door weatherstripping just tug and pull off or are they screwed/hooked in? The entire door frame one. If so is there a tutorial w/ pics or YouTube? |
Re: Door panel Screw sizes; triangle and handle bezel
1 Attachment(s)
The parts manual list the mirror triangle screw as an oval head with trim washer, 4.2x1.41x30 AB PT Torx 6010M. Part #11516302. The door handle bezel screw is an 4.2x1.15x20, part #10092102
As for the weatherstripping, I attached pages from the service manual that may help. |
Thanks for the info. Unfortunately the Ace Hardware guy and I couldn't decipher them.
These screws are metric.
I'm pretty sure these are very similar to the ones used for mirror trim. The length may differ, but they're probably longer than the originals. The door handle bezel screws I thought had more of ahead like these, but I'm not sure. I'll have to go over to shop tomorrow and check. |
This isn't totally off topic and seems like a good place to ask.
Anyone know the size of the two "large" bolts/screws that secure the door panel to the door? They go in through the "grab handle" of the door panel, one through the top and another through the bottom. They are Phillips head and probably 1.5"-2" inches in length. I seem to have misplaced, or lost, one when I removed my panel years ago to the replace a window motor. I finally got around to putting the motor in over Christmas and noticed I was missing one of those screws when I went to put everything back together. My car is a 1994 and I believe I'm referring to 202 in "Figure 5 - Front Side Door Assembly (Chevrolet)" on page 10-6-8, and also Figure 8 on page 10-6-10, of the Factory Service Manual. Would the FSM list the sizes anywhere? My plan is to just take the one I have to a bolt/screw store and see if they can match it, but was just curious if anyone actually knew the size. |
202 is M6.3 x 1.8 x 40 . Screw sizes are not generally listed in the FSM, but in the parts book.
4th Gen Parts Manual download is available here - courtesy of GaryDoug:
https://www.mediafire.com/?40mfgeoe4ctti |
Thank you both.
