Door Cracks
My '02 Formula has a crack in the right door panel along the top of the panel just under the window. Doing some internet browsing for a replacement panel shows me that this is a common problem for '97-02 Fbody door panel. As I have had no luck finding a replacement I was wondering if anyone has had any luck covering the plastic portion of the door panel with a vinyl wrap. Any suggestions or source for a replacement would be appreciated.
Re: Door Cracks
I just saw an article on repairing the door panel, without covering anything:
How to fix your already cracked door panels Not a totally invisible repair, but looks decent. |
Re: Door Cracks
Has anyone ever tried adding some type of filler and then match the texture of the door panel?
Re: Door Cracks
Originally Posted by birdblack
(Post 6975247)
Re: Door Cracks
pretty much all my friends with TA's have this problem.
Re: Door Cracks
(Post 6975247)
If the crack seems too visible, as in the later black panel in the article, any sort of filler could be pressed in, and touched up. SEM makes some fairly good matching vinyl paint (Eastwood sells them under the Eastwood name as well), and whatever you fill it with could be painted with a very tiny brush. |
| All times are GMT -5. The time now is 05:54 AM. |
