99 Z28 (removed stock grill) glue removal??
Old 09-14-2009, 08:21 PM
DOLPHINS84's Avatar
Does anyone have any ideas on how to remove the glue from beneath the stock grill after the stock grill is taken off?
Obviously without damaging the paint.
Any ideas would be helpful thanks.
DOLPHINS84 is offline
Old 09-14-2009, 09:53 PM
Rebelphotog96's Avatar
I have no clue what to tell you about glue.... Was it the stock grill? I've NEVER seen one glued on. Just clipped in. You can try Goo Gone, Oops!!, or Goop Off. Other than that, I don't know. Good luck!
Rebelphotog96 is offline
Old 09-15-2009, 10:08 AM
Z28SORR's Avatar
Alcohol, WD40, cleaner wax, etc. Must be dozen of product.
Z28SORR is offline
Old 09-17-2009, 07:49 AM
Lt1 and Ls1's Avatar
Just removed my grille, and there wasn't any glue
Lt1 and Ls1 is offline
Old 09-20-2009, 10:51 AM
DOLPHINS84's Avatar
http://www.cardomain.com/ride/3383208
here's a link to my cardomain I recently made, scroll down you can view the glue on the front
Old 09-20-2009, 10:05 PM
Hmm...dunno where that came from, but it's definitely not factory.
Old 09-22-2009, 06:29 PM
yy
yy's Avatar
Sometimes when the grill doesn't stay put because of broken clips, etc., people tend to glue them on. First of all, try something like WD-40 as this will not damage your paint. If the glue is soft, try to gently scrape most of it off with your fingernails. If the glue is very hard, then try using some acetone very gently. You do not want to scratch your paint. Hopefully your car is a darker color like black. As long as you don't break through all the layers of paint, many of the scratches can be removed by gently wetsanding with a high grit sandpaper (2000) and then buffing out.
yy is offline
97SSdude
12-31-2014 07:43 PM
cmdeshon
12-27-2014 10:06 AM
12-17-2014 11:00 AM
Mikes 1994 z28
11-25-2014 02:00 PM
Quick Reply: 99 Z28 (removed stock grill) glue removal??
