94 camaro door loose help?
so i have my 94 camaro v6 hard top and the door is loose. not exactly the door hinges etc but the part in the door where it splits and the window comes out is loose so the window wobbles around a little bit and it rattles when closing the door and is quite anoying. is a bolt loose or maby a bolt off? and is it something that can be fixed with a wrench in 10 min? or much worse?
thanks heres some pics.
^^^^^^ pictures of me spreading apart the part where its loose
^^^^^^ outlined wich part is loose and coming apart in red
thanks
thanks
