38mm or 56mm off-set on ZR1s?
which wheels should i get on my camaro? im not familiar with wheel off-set so i really have no clue what the difference is. any help would be greatly appreciated.
Brad
1997 Z28 M6
T-tops, chrome rims, all options, SLP Dual/Dual, cutout, !CAGS, FIPK, LT4 KM, Air Foil, TB bypass, pro 5.0, OBD1, !EGR, !AIR, CSI waterpump, 160* thermostat, 1LE intake elbow, PCM tuning by, www.PCMFORLESS.com , taylors, singe-cat SLP shorties minus the cat!
Brad
1997 Z28 M6
For the 9.5" wheel, 56mm is what I have and it works/looks good.
If you are looking at getting the 11" rears, the 50mm offset is probably your best bet and will require the least amount of modifications to the car.
Brent Franker * Main Page
94 Vortech Z28 * 96 Z28 SS #1655
4th Gen Appearance Modification Guide
F-Body Install & Fix-It Guides
