What timing are you running at WOT
I was wondering what timing you guys are running at WOT. I have a solid roller 396 with 248/254 duration , 6.xx ish lift camshaft. I know every motor is different but shot me your numbers anyways. Thanks
Mine is set to 25 degrees base and 36 full timing.
The trick is to get as much advance curve as possible without detonation/ping. My timing is fully advanced at around 3000 RPM. I used a spring weight kit to adjust the timing curve. An improvement can really be felt from the stock setting. The optimal full advance timing can be found by playing on the dyno, or getting your best MPH speed in the 1/4 mile. My specs can be found at the links in my sig. Too many options to list here. |
i was seeing 39 - 40 at WOT ... my engines quite high compression as well ... running on 94 octane gas.
though some people think thats too much and is actually hurting my hp #s ... |
