Slack in tv cable 95 z A4
Old Aug 3, 2003 | 09:27 PM
RacinZ's Avatar
I just recently bought a 95 Z that had nitrous throttle plate taken off and I noticed that the tv cable is slack about 1/4th inch. Is this correct I know on my ford aod there is slight presure even when the throttle body is fully closed. Seems to shift fine but I think it should be tighter any ideas? thanks
Old Aug 3, 2003 | 11:43 PM
I thought since the 4L60E (94-97) is electronically controlled, only the 4L60 in the 93's has a TV cable. Are you talking about the second cable on the side of the throttle body quadrent? That is the cruise control cable on your 95.
Might want to clarify exactly which cable you mean.
Old Aug 4, 2003 | 11:05 AM
RacinZ's Avatar
hmmm well I'm not sure now. I guess I will check. My trans is a TCI and convertor package, maybe its different. thanks
Old Aug 4, 2003 | 11:09 AM
RacinZ's Avatar
well I dont have cruise control
Old Aug 4, 2003 | 06:21 PM
LJ93Z28GM's Avatar
This will likely get moved just to let you know but the possibilities of cable going to the TB are going to be:
Traction control
Cruise
TV Cable 93 only unless possibly converted
Throttle
Old Aug 7, 2003 | 10:11 AM
RacinZ's Avatar
well Mr. Moron here, I do have cruise its on the side stalk like most Gm's have I had a brain fart (happens to us over 40) My stang has it on the wheel. Guess I've been driving fords to long Thanks for the replies I guess even when you have gone and built 8 sec na cars you still can be stumped by something so simple before checking the obvious Andel
Old Aug 7, 2003 | 11:07 AM
Welcome to the age of "the senior moment".... I know it all too well.
Fred
G-BODYT56
Jan 14, 2022 11:14 PM
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
marlar98
Sep 19, 2015 07:53 AM
