Ring Gapping ??
Old Jun 27, 2005 | 04:23 PM
ChiTownHustler's Avatar
Ring Gapping ??
I am gapping my rings right now and I purchased a Summit diamond ring filer. The abrasive wheel is only 1 sided.
Does it matter which side of the gap you file, or should they both be filled almost equally, or doesn't it matter just as long as the gap is correct???
Old Jun 27, 2005 | 06:51 PM
SStrokerAce's Avatar
Re: Ring Gapping ??
I file one side so on teardown (if you ever do) you can tell if they were touching or not.
Bret
Old Jun 27, 2005 | 11:40 PM
Stephen 87 IROC's Avatar
Re: Ring Gapping ??
I gap my rings by mounting a file in a vise. I only file one side until I get the gap I want.
Old Jun 28, 2005 | 08:34 PM
1racerdude's Avatar
Re: Ring Gapping ??
My C&A electric only does one side. Make sure they are square with each other when squeezed together and held up to a light(sun),no taper or wedge.
magman
Apr 15, 2016 03:08 AM
Quickss96
Jan 29, 2016 05:56 PM
IndyZman
Oct 22, 2015 02:17 PM
mmf_1013
Sep 12, 2015 08:56 PM
blaze309
Sep 8, 2015 05:27 PM
