Is this right?
Old Sep 29, 2002 | 09:13 AM
MichiganSkip's Avatar
Is this right?
"The heads retain stock valve sizes because torque will suffer with bigger valves unless your LT1 bottom end is radical or your running a stroker motor. (do the research) "
Found a set of LT1 heads on Ebay and this comment was made . Is this right? If so what's the reasoning?
Skip
Old Sep 29, 2002 | 07:07 PM
drop top steve's Avatar
Large runner volume with BIG valves, YES. LT1 heads with an average port job, 2.00/1.55 valves should have little or no effect on low end TQ.
