CamaroZ28.Com Message Board
-   Advanced Tech (https://www.camaroz28.com/forums/advanced-tech-38/)
-   -   Fuel Line Conversion Help! (https://www.camaroz28.com/forums/advanced-tech-38/fuel-line-conversion-help-368847/)
XxXTransAmXxX May 20, 2005 02:50 PM
Hello guys....
I am wanting to know all the PN's, or a write up, etc... on the following process..I am aware it can be expensive, and am willing to go that route.
I wanna know what all is needed to run Stainless Steel Line from pump, to fuel rails. I have filled in the engine bay seams, and existing hole for the fuel lines, an now I would like to hide them and route them to the back of the motor, instead of that ugly loop from the front!
I will need to know hose sizes, fittings needed, and fittings sizes, etc...
Feel free to email me, if you dont wanna post here at XxXTransAm2@aol.com or IM me on AIM @ MxRacer476...
texasTA May 21, 2005 11:31 AM
Re: Fuel Line Conversion Help!
I need to know the exact same thing. Anyone help???
Highlander May 21, 2005 11:33 PM
check out LJs page... its very informative
para.noid/~lj IIRC.
I did something very similar only i used braided all the way... i used a twin in tank from racetronix already converted for 8 feed -6 return.
It was very simple and my friend Jose Albertorio did the installation that looks 100% factory.
Injuneer May 22, 2005 12:52 AM
Twin Bosch 205lph pumps, one in the tank, one outboard off a sump on the back of the tank. Pumps each have a -6AN line, connecting to an NOS "Y" fitting in front of the axle. -6AN to an SX billet filter in the stock location. -6AN line to the front of the car, up the firewall behind the engine. Another NOS "Y" fitting splitting to 2 -6AN lines, one into the back of each fuel rail. -6AN fitting from The Chassis Shop welded to the back of each rail. 1/4" NPT aluminum bung welded to the middle of the passenger fuel rail for a pressure sensor. -6AN fitting welded to the diagonal crossover pipe at the front of the rails. -6AN return line to a Weldon AFPR under the cowl. -6AN return line down the firewall, to the stock return port at the fuel tank.
Outboard pump, Y-fitting and filter: http://cjcfo.fbody.com/members/injun...A/FuelPum3.jpg
http://cjcfo.fbody.com/members/injun.../DCP03672a.jpg
http://cjcfo.fbody.com/members/injun.../TA_12Bolt.jpg
Supply and return lines (plus -6AN nitrous line):http://cjcfo.fbody.com/members/injun...TA_MW_Muf1.jpg
http://cjcfo.fbody.com/members/injun...tosC/TAMnt.jpg
Back of rails and AFPR: http://cjcfo.fbody.com/members/injun...A/FPRLines.jpg
http://cjcfo.fbody.com/members/injun...E/dFuel4AN.jpg
Pressure tap and sensor: http://cjcfo.fbody.com/members/injun...sA/FPRSens.jpg
Return line: http://cjcfo.fbody.com/members/injun...s/210Fuelc.jpg
http://cjcfo.fbody.com/members/injun...A/FulRlMod.jpg
Deleted 3-line bundle: http://cjcfo.fbody.com/members/injun.../DCP04251a.jpg
blown383 Feb 6, 2006 12:11 AM
Umm... Fred can you relist the links again? They no longer work. =(
-B
Injuneer Feb 6, 2006 06:39 AM
Unfortunately, the server they were on at fbody.com is no longer working.
blown383 Feb 6, 2006 12:47 PM
Then do we have any other resources on a complete step by step build up on a fuel system?
-B
Injuneer Feb 6, 2006 03:14 PM
I just posted a bunch of pictures. It wasn't intended as a step-by-step. It was just showing one way to do it, that seems to work very well. I don't have a lot of the details, because most of the work was done by a shop in PA, while I was working in Italy and flying back and forth periodically.
