Flat milling the LT1 Aluminum Head
Old Aug 28, 2004 | 01:41 PM
chrism400's Avatar
How much can you safely mill the aluminum lt1 head? I think I have heard as much as .030. What is the net cc per thousandth milled? When do you have intake manifold sealing/matchup problems? What head gasket should I use to get more compression with reliability? Should shim gaskets make me nervous with an aluminum head mating a cast iron block? Thanks,
Chris
Dayton, OH
Old Aug 28, 2004 | 03:54 PM
LT4orbust's Avatar
Talking Re: Flat milling the LT1 Aluminum Head
Good luck!!! I've asked this question a few times, no answer
Old Aug 28, 2004 | 04:53 PM
Mindgame's Avatar
Chris
Dayton, OH
1cc for every .006 milled (flat milling).
What's your target for static compression? May not be necessary to mill too much if we know this.
Yes, the intake will need a correction for heavy milling (.030 would qualify). Same goes for angle milling... the intake needs correction.
WRT head gaskets, the composites from Fel-pro and Rol are good gaskets. If the heads and block are machined with the right surface finishes, you could use a Multi Layer Steel (MLS) gasket. You need to determine a quench distance before considering a gasket. All plays a part in determing that target static compression ratio.
-Mindgame
Old Sep 4, 2004 | 09:09 PM
LT4orbust's Avatar
will a machine shop know what to do to the intake if .030 is taken off of the head? I'm planing on taking off .020 on my aluminum heads ...will any intake work be needed, if so which surface and how much ? Thanks,
Old Sep 4, 2004 | 10:46 PM
chrism400's Avatar
The shop here says that the head can be safely milled .030. If the block is decked, that needs to be done too, then, they place the heads on the block and measure where the ports line up on the intake. They can then determine how much needs to be milled off of the intake. It's no big deal I guess.
Old Sep 4, 2004 | 11:55 PM
amean94ta's Avatar
i had mine milled to 50cc i dont rember how much they took off though
Old Sep 5, 2004 | 07:46 AM
SAR2K's Avatar
Arrow Re: Flat milling the LT1 Aluminum Head
The major limiting factor is the intake valve seat location. With stock seats you can take off .010 - .015 without issue. More than that and you need to pay close attention as to how close you are to the seats... I've seen some "out to lunch" seat locations (as far as distance from the deck) from GM on these heads.
Steve...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
*Emilia*
May 13, 2015 09:05 AM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
