Ferrea 6K's wich flow better
Wich valves from actual experence will flow better in a smallish 1.94 size.Im looking at the 12* heads and the 10* heads..Im not trying to take a day off of work and spend $500 on a flow bench so if somebody has some insight id apriceate it a lot.
The 12* will flow better with a stock type of head, There are some advantages to the 10* such as if you are going to turn a lot of rpm, the 10* is quite a bit lighter than the 12*, and can be made to flow as well as the 12* if you know what you are doing portwork wise.
So, most applications I would run a 12* unless I was going to turn a lot of rpm regularly, I would get the 10* and make it work.
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
