Cam question (Nitrous related)
What's the theory on the "nitrous grinds"? I'm thinking of changing cams and want one that will optimize my nitrous set-up. I'm not too concerned about N/A perfomance as it's also a cruiser.
What specs should I look for on a "nitrous " cam? Skip |
How much Nitrous?
Mostly if it's a cruiser I would look at a cam with a higher LSA number. Usually that and a longer exhaust duration help. There are also some tricks that racers do with the lobes on Nitrous Grind cams. Mostly it's shutting the valve extremly fast. Bret |
150hp shot. It's got stock heads, A4, PI 3200 and 3.73''s. I e-mailed Comp Cams about a suggestion but got no answer. Would I have to come up with some numbers and then have someone grind a cam to those specs?
Thanks Skip |
