Y-pipe manufactured for hedman long tube headers?
Old Dec 14, 2003 | 09:45 AM
kbog54's Avatar
I was wondering if there was anyone that made a y-pipe to fit the hedman long tube headers
http://store.summitracing.com/partde...rt=HED%2D68460
All of the y-pipes that I have found are for the shorties.
Also, if I cant get a y-pipe, will the hedman x-tensions clear my '83 Z-28?
thanks
Old Dec 14, 2003 | 01:17 PM
IROC-T's Avatar
If you can't find one any GOOD muffer shop should be able to fabricate one up for you. Just let your fingers do the walking(call around)I'm sure you can find some one that can and will.
Old Dec 15, 2003 | 12:10 AM
Zepher's Avatar
Are these the ones you have?
500-68460
Camaro/Firebird 1982-92 265-400 ci, 1-5/8'' Tubes/3'' Collector,
Full Length Header
*Fits Chevy engine
*Will fit with angle plug heads
*Dual exhaust only, limited ground clearance
*Must modify rotary A/C bracket
*Designed to fit and clear with 700R4 or TH-350 transmissions.
I have these on my car and will be running a dual exhaust setup.
Old Dec 15, 2003 | 09:59 AM
kbog54's Avatar
yeah, those are the same ones that I have. I dont want to weld up dual exhaust, so I think that I'm just gonna fabricate my own y-pipe with the headman x-tensions and a flowmaster y.
thanks
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
NED4SPD
Sep 16, 2002 10:45 PM
