Will the shorter iroc front springs fit on a normal z
Will the 1 inch lower front springs for an iroc fit in my 85z without mods? do I need different struts or are they all the same?
------------------ 1985 camaro z 28, 305, std, stock stereo, stock exhast, repaired dash, used to have over 30 dents (very few left), new battery with hole melted in it from welding, new choke, replaced alternater, rebuilt starter, new wipers, added coolant, 3 core rad, bald tires, maroon and gold, primer gray, primer red, and blue, back left ground effect damaged slightly and has gap between body, cracked shifter knob, finally got the secondary's in the carb to open, fixed timing, half made hoodscoop, broken front left strut, 3.23 gears, no posi, fairly new clutch, new trasmission mounting setup. |
I'm not sure if they're an inch lower or not, but yes all 82-92 thirdgen springs and shocks are direct swaps for each other.
------------------ 1991 Camaro Z28 350 L98 w/ T56 (originally 305 LB9 w/ T5) 318 RWHP, 419 RWTQ 12.803 @ 108.50 MPH (1.932 60') Member: SoCal F-Bodies ThirdGen 4-Life! |
They are a .5 inch lower and yes they will fit.
so let me get this straight... you want to jack up the back of the car and lower the front? You must really like that sensation from going down a hill.
------------------ The IROC Homepage View the Restoration of an 85 IROC Weekend projects aren't. |
