Blownyellow |
11-02-2002 09:19 PM |
What I mean is that at 2500 feet where I am at 305 tpi cars usually run from 15.5's to 15.0's stock. If you were to take the car that ran 15.5 at 2500 feet down to sea level it should run in the fourteens. So since you are running at sea level with an exhaust and air filters, your car should definatly be running in the fourteens. If you haven't already, I would suggest going through everything such as plugs, wires, timing, fuel system flush, and whatever other tune up things you can think of to get your car running as good as it can.
