stupid question im sure but im new to carberation
Old Mar 22, 2011 | 08:58 PM
Cbystrack's Avatar
i just bought a new holley carburetor because my last one was junk, anywho the new one has vac control secondaries and i have an hei dist with a vac advance block off......... what do i hook it to now? sorry if this is a dumb question but im lost at the moment... thanks - Chris
Old Mar 23, 2011 | 01:35 AM
ZZ's Avatar
ZZ
Re: stupid question im sure but im new to carberation
Not sure what you are asking, but I'll take a stab at this. If you are reffering to the vacuum signal for the secondaries, that is supplied internally. Just bolt it to the intake and you are done. If you are asking where to hook the vacuum advance, you can either use manifold vacuum, or the timed spark port on the passenger side of the primary metering block. I prefer manifold vacuum on a SBC. The timed spark only gives advance after the throttle opens some, then drops at full throttle. Manifold vacuum is present at idle where you need more advance to run a little smoother and cooler without moving mechanical advance, and also drops at full throttle. The timed spark doesn't give advance at idle. Don't know if this helps or not.
Old Mar 23, 2011 | 08:47 PM
Cbystrack's Avatar
zz, you answered my question in full. thank you very much!
Magenta_Hearts
Mar 5, 2015 07:01 AM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Brent94Z
Mar 21, 2002 04:44 PM
