Shake, rattle, and roll
Hey, guys...this may turn out to be a really simple question - but I wanted to get your spec on it (at the risk of looking stupid
When I'm driving at around 60 to 85, my car shakes pretty bad. It's pretty smooth under 60 or over 85. I had an alignment done, but it doesn't seem like it helped. The front shocks are going out, and the tranny is dying a slow and painful death...so what should I attack first to fix this problem?
).When I'm driving at around 60 to 85, my car shakes pretty bad. It's pretty smooth under 60 or over 85. I had an alignment done, but it doesn't seem like it helped. The front shocks are going out, and the tranny is dying a slow and painful death...so what should I attack first to fix this problem?
One of two things is happening:
1. Your tires are out of balance. Have them checked. #1 cause of vibration
2. You have a steel driveshaft right? They are known to "deathwobble" around those speeds. Look around and get an LS1 aluminum driveshaft.
That should solve it. Other things that could cause the vibration are worn wheel bearings or bent axles. Try the 2 suggestions first though.
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner, K&N filter, Edelbrock headers, Catco cat, Hooker cat-back, built 700r4 w/ Darrell Young 2400 stall TC, Jet stage 2 chip, SSM subframes, Lakewood LCA's, Powertrax locker w/stock 3.23's, Centerline Auto Drag's
If your shocks are worn they too can cause this vibration. If you have many miles on the car as most do worn ball joints can contribute to vibrations. I recently overhauled my suspension front and rear and what a difference, unbelievable. I previously had the drive shaft overhauled and balanced so I knew it was OK so a suspension overhaul on my 195,000 mi Z was in order. The car handles like never before and rides nice considering it's an F-body.
92BLKL98
'92 Black Z28 Hardtop Modded 700R4, MSD
Ignition, March Underdrives, TPIS Fastpak, Ram air w/gutted filter box, SLP Prom, Flowmaster, & free mods Random Technology cats, Amsoil synthetic lubes, CE SFC's, Edelbrock STB,Spohn TA,Roadtech LCA's and Panhard Rod, Energy Susp., PST polygraphite bushings, KYB Shocks.
92BLKL98
autoxr166
Sep 25, 2015 04:21 PM
cmsmith
Sep 14, 2015 09:25 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
Synchrony? What's that?
