Runs better when MAF Disconnected..
My car runs better when the MAF is disconnected, what would cause this? My MAF was hanging bout 2 months ago and was 1 of the 5 pins got ate up by my alternator band.
Any help on whats goin on here?
My buddy has a 96 Mustang. He left his MAF unplugged by accident for a run down the track. It was his best time ever.
Don't know what to tell you. I just remember when I had my IROC, I had the most problems trying to get my car to run right because of that stupid code 33.
Yes, you have a bad maf sensor. That is actually a pin point test for a map sensor, to disconnect it and see if the engine runs better. Give it a good visual before you toss it. I hope the screens are still on there
ok, i went the the local kragen, i asked to see the Mass Air Flow Sensor and they brought out the whole big peice that goes under the little sensor connects to. All i need is the sensor that connects into it, comin from the wires n all that cuz 2 of the little pins got ate up by my alternator band. I dont think i need the whole peice.
What do i ask for when i try to get the piece?
You can't get the plug only, you HAVE to get the whole thing. Trust me, I know. Dont even try to get the plug part. If you do try to get one from a junkyard car, don't even think about removing the plug section, put the whole thing in. If you do try to remove it, 99% chance you'll break it.
formula218
12-02-2014 04:27 PM
