quick question about a flywheel please help fast
i am getting parts together for my tranny swap auto to t-5, and i need some info on flywheels,
one guy had one from a 91, which would be a 1 piece rear main correct?
my engine is a 2 piece rear main cuz its an 84, can i use the flywheel from the 91 or will it not work?
if not what causes it to not work?
Pics of the Firebird
84' Firebird, 305ci lg4, 700R4, 288/292 duration .450/.460 lift,Edelbrock Performer intake, Holley 600cfm 4 barrel, K&N filter, Pacesetter Headers, 3'single exhuast, dual out muffler, no cat,Motive 3.73's and Auburn Posi
1/4mile 15.17sec @ 92.5mph
84 firebird, motorless and trannyless at the moment (was 4cyl 5spd)
parts car/race car, (at least it will be eventually)
come on guys a lil help plaese?
I don't believe it will work. If I'm not mistaken the one piece crank flange is smaller than the two peice.
92BLKL98
'92 Black Z28 Hardtop Modded 700R4, MSD
Ignition, March Underdrives, TPIS Fastpak, Ram air w/gutted filter box, SLP Prom, Flowmaster, & free mods Random Technology cats, Amsoil synthetic lubes, CE SFC's, Edelbrock STB,Spohn TA,Roadtech LCA's and Panhard Rod, Energy Susp., PST polygraphite bushings, KYB Shocks.
92BLKL98
'86 and newer Chevy V8 one piece rear main seal cranks have a smaller flywheel bolt pattern, so the flywheels won't even bolt up to the '85 and older cranks. Also, I believe the '86 and newer cranks are external balance (counterweight on the flywheel and damper) instead of internal.
91 Camaro RS
Too many mods to list here
http://www.quick91rs.cz28.com
91 Camaro RS
ok new question, can i use a 14 inch flywheel, with a stock t5 bell housing?,
my step dad has one, we think it is from a big block, the part number on it is 3729004, it does not appear to have any weights attached indicating that its an external balance, which is what i need correct?
