Pitman Arm - Idler Arm - Labor Involved - Any Kits?
Hi all,
Was wondering if anyone knew what was involved in chaning out the pitman arm and or the idler arm. And also brands to use etc...
I took my car in to get checked about a year ago and they changed my lower ball joints because I had told them I had an accident awhile back on the highway i hit what to me looked like a very large pipe with my front right tire. I pulled over and the tire didn't go flat but a few days later I realized my car was shaking. After checking out the front I noticed the my front right wheel was bent the inner lip of the wheel. So I got new identical wheels changed the tires etc.
Well that got rid of the vibration but when I pass about 50 miles on the highway the car does this wierd thing were if it find a grove on the highway it pulls left then like a few seconds later pulls back to the center. So anyways they checked out my car and said it was the lower ball joints. They showed me the play and I got that done. They also told me that the car's pitman arm was also on its way out but still ok.
Anyways a few months later after not running to car for too long (cause I use to work by my job so I would walk) I noticed the car was still doing that movement above 50. I got the car realigned btw just to make sure and still it occurs.
So I think I am going to attempt to change the pitman this weekend. Any recommendations on what and from where to buy? I read that Moog sells a complete kit that includes the pitman and the idler arm for about 150...not sure if its tru. Also is this a tough thing to change? I think I can borrow a pitman arm puller from autozone...
thanks and sorry for the long post...just want to be as detailed as possible =)
here's a tech article i wrote on changing the idler arm http://www.fl-thirdgen.org/idlerarm.html
pitman arm you can rent a puller from AZ. you'll also need a pickle fork (ball joint separator) the tuning fork looking thing in the pics.
if i remember correctly, the pitman arm is a non replaceable item. meaning it has 2 holes. one for the steering box and one so the centerlink goes into it. look at it real close just to make sure. i couldn't find any pics of my car with the pitman arm in it. moog sells the idler arm separately.
Re: Pitman Arm - Idler Arm - Labor Involved - Any Kits?
Hi all,
Was wondering if anyone knew what was involved in chaning out the pitman arms and or the idler arm. And also brands to use etc...
carguyshu
01-22-2017 11:19 AM
