Need help with a vacuum line..
RIGHT behind the carb, coming out of a fixture out of the intake manifiold, there is a vacuum line. All of a sudden it's disconnected from wherever, and the car runs like sh*t if it's not plugged. I cannot find an opening to where it might go though; any suggestions?
Matt
Matt
Re: Need help with a vacuum line..
how big is the line? it very well could be the brake booser if its a large linei n diamater. otherwise, check the egr valve vacuum line, make sure its not the pcv valve hose, etc. Get a book, it will tell you the vacuum routing, since I assume yourdiagram from the factory is either long gone, or covered over with dirt and grease.
it's not the brake-booster line, I already checked that. It's not PCV either
I have a haynes manual, but what should I look under; vacuum routing? Thing is it's NOT the stock carb or distributor that's why I was confused..
If it doesnt go to your EGR, Distributor, pcv, or barke booster, then go down to a parts store and see if you cant get some of them threaded steel plugs to screw into the manifold to block off the line. I'd just block it off somehow.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
