My LT1 swap ta
Old 10-06-2010, 04:57 PM
1badeagle's Avatar
My LT1 swap ta
Heys guys,
Im currently in the middle of swapping a lt1/t56 combo into my 84 formula. Its a 93-97 f body lt1 with gm847 cam, le2 heads and intake, hooker headers,58mm bbk, new std forged pistons and new procomp rods with cap screws.
Any ideas what she will run in the quarter. Race weight will be right at 3000 with me in it. Also 9 bolt bw rear with 3.45 posi rear.
Dustin
1badeagle is offline
Old 10-07-2010, 12:58 AM
cars3's Avatar
There was no 1984 formula. They did not start until 1987 in the 3rd gen.
cars3 is offline
Old 10-07-2010, 04:48 PM
1badeagle's Avatar
THere is a 1984 formula cause I swapped all my parts from my wrecked 88 onto my 84 lol
Old 10-07-2010, 05:38 PM
Gtpguy's Avatar
Well, GM847 cam only cars are dipping into the 11's. So with heads and a couple hundred pounds less weight, do the math. Thats assuming you can drive and have drags and the tune is good. You might want to step up the gears as well. That cam loves high rpms. I'd get a set of 4.10s or even 4.30s and call it a day.
Gtpguy is offline
Old 10-07-2010, 08:08 PM
1badeagle's Avatar
Thats good to hear man. Im planning on upgrading to a 9" rear with 4.10 or 4.56 when my factory one break. I also plan on sticky tires as well. How much abuse will my t56 take with this kind of power and sticky tires?
My cars biggest downfall with drag racing will be the fairly stiff road racing suspension.
Old 10-07-2010, 11:01 PM
cars3's Avatar
I guess you would be correct then.
cars3 is offline
Old 10-07-2010, 11:05 PM
1badeagle's Avatar
Yea I really just perfer the Formula body syling over the Trans am. Its gonna be bad ***
Old 10-08-2010, 04:07 AM
Gtpguy's Avatar
The T56 will be fine with what you have in mind. They are pretty tough. I thought it was good for up to 500hp/500tq. Your hp should be in the low 400s and torque should be close but a bit lower.
Gtpguy is offline
Old 10-08-2010, 05:07 PM
1badeagle's Avatar
I was curious and didn't figure them to be that high. My hp goal is around 400 at the wheels. That should be a wicked fast street car that not many others with to run with.
Noer
02-28-2015 11:29 AM
rocketman051894
01-30-2015 03:23 PM
InfernalVortex
01-17-2015 09:35 AM
cmdeshon
01-04-2015 11:15 AM
Hot Rod Hawk
08-30-2002 10:12 PM
Quick Reply: My LT1 swap ta
