knock sensor
1991 camaro z28 5.7 tpi
where is the knock sensor located? i cant find any diagrams of where my knock sensor is on my car. What does it look like? i keep getting different pictures of what it looks like. |
i found something with a weir pluged into it between my last 2 plugs on my passenger side.
it looked bad, it was very rotted and it seemed to be broke at the end. |
Doubt that's the knock sensor. on the 3rd gens the knock sensor is either on the lower part of the block just above the oil pan or at the rear of the right cylinder head
If you have the haynes manual it shows a clear picture. I have the firebird manual but the motors are the same for a firebird or camaro. My manual shows a clear picture of it on page 6-10. If you do not have one you could check your local libray and see if they have the manual.
yeah that's where i looked up to give him the location. I don't have a 350 though so i don't know exactly which location it is for him
thanks ill try looking at that.
its right by the starter and motor mount.
thanks man, im going to try and replace it now.
is that on the the driver or passenger side????
should be driver's side. if i remember correctly when it says right side it means driver's side because that's what on the right when you're looking at it.
Originally Posted by SupplySgt.
(Post 5958943)
Originally Posted by tgates
(Post 5954892)
(Post 5958053)
cool. im going to look into it when i get a chance. i will report back if i have any problems.
i found the sensor and i unplugged it. how do i tell if it is faulty?
FIXED! thanks for everyones inputs.
