If you had $3000 to spend how would you spend it?
#18
being from california i would het the gears first because they work with everything, (carb) headers, shift kit, all the stuff they can't sniff but will make you faster. don't worry about the unibody.
if you want to upgrade brakes cheap, check out the other posts they have great ideas on brakes. the paint is the most expensive and you might not get it done for 3000. try to get parts that will upgrade and not hinder when you decide to go with a big 383 stroker. good luck . btw nitrous is a cheap go fast fix
#20
If it were me I'd start with option 2, that would be a good starting platform for future mods. What good is a bunch of POWER and FANCY PAINT if you can't stop it from wrapping around a tree!?
#22
jeeze your thread helped me out a bit ;D
i just realized i dont have sub frame connectors on my car. it has t-tops. i havent bent anything yet but id rather be safe then sorry. thz for helping me while helpin him guys =P
where would i go about purchasing these?
#23
Well Here's what I decided on so Far:
Big Brake Upgrade, "LS1" $735 shipped
http://www.metzcon.com/bigbrake/products.htm
I'm having Alston's Sub frame connectors welded on by Dyno Don here in So. Cal. $245.00 installed
I found a paint shop through friends that is going to give me a first class paint job including softball sized dent on Passenger's door, removal of all rubber before paint and then reinstalling it, grinding and repairing the rust under the T-Tops. $2500.00
I know I spent more than I planned but my bonus was more than I thought even after taxes.
So thanks for all the advice Guys
#24
personally i prefer grunt over looks
but seems like u made a good choice. if its running mint and reliable then hell i would do looks too. unfortunately for me im at the "working out the bugs" stage lol. finally got over my heating issues though thank god ;D then heater core, then fuel pump, then head gasket... ect lmao
but heh get some b4 pics and after. i wish i took before and afters of my engine bay ;D i got mad room after removing ac, power steering(put in vega box) and basically remove anything that wasnt vital hehe.
#25
Oh and I also bought a 93 Camry to drive around while my IROC is being worked on. That pretty much eats up my paint money. But my car still isn't ugly, it looks good from 10 feet away.
#26
whitehooptie
08-10-2015 07:02 AM
Devinfoote87
07-30-2015 09:54 AM
