Help !!
Old Dec 22, 2011 | 05:38 PM
GOONS1_89/Z28's Avatar
Question Help !!
i got an 89z28 irocz but it has an older carb engine in it jus rebuild the engine this year and the pos cable acidentaly grounded off due to a bad tape job that i didnt know about it wornt turn on but i think its the spark that its not giving it cranks but it doesnt spark any ideas please sum helpthan
Old Dec 23, 2011 | 05:13 PM
quickchicken's Avatar
Re: Help !!
check all of your fuses in the fuse block and also look down where the hot wire ties in to the starter and see if you have a few red wires that are burned in 2. those are fuseable links and this is a strong possibility where your issue is. afte that get a new bat wire and take care on installing the new cable.
