disconnecting fuel return lines and fuel inlet lines on the throttle bodies
I have a 1983 crossfire camaro trying to figure out how to disconnect the fuel inlet line and fuel return lines connected to the throttle bodies, last time I tried to turn them I ended up bending a line slightly
If I recall, you need to hold the fitting on the throttle body, and use a line wrench on the tube fitting, same as a newer tbi unit, but a picture would help
Re: disconnecting fuel return lines and fuel inlet lines on the throttle bodies
it said to disconnect in the hayes manual but yea no describtion to how I was thinking some kind of penatrating oil after all this car is older than me
Try posting in one of the tech sections. This is the off-topic area.
If you don't start posting these questions in the tech forums, where they belong, your account will be closed.
Moving. |
| All times are GMT -5. The time now is 12:36 AM. |
