Help my 1986 Camaro Iroc
Old 04-13-2010, 08:51 PM
Quarantine's Avatar
Hello.I need help on a couple of things.I have a 305 v8 5.0 Engine,I would like something with more hp(nothing crazy)Can you recommend something,and what would I need to make stronger to support all that hp (tranny,shocks etc)Thanks.IT's a 86 Camaro Iroc z28 305 engine v8 5.0 fuel injected I believe.Oh,it's not posi I'm told,how can I make it posi in the rear?Thanks
Quarantine is offline
Old 04-14-2010, 05:34 AM
You need to post this in the correct forum.... right now you're in the "Appearance" forum. I'll move your post to "3rd Gen/L98 Engine Tech". You'll get more info on HP and engine swaps there.
With regard to the limited slip differential ("posi") - have you verified that you have an
open" differential? When you do a "burnout", do the tires leave two black stripes, or one? Have you checked the build code tag to see if it has the code for a limited slip differential?
IF you don't have a posi, you have to swap in a new "carrier" that incorporates a limited slip unit. Alternative is to buy a complete rear axle assembly from a car that does have a limited slip rear.
Injuneer is online now
Old 04-14-2010, 09:54 AM
Quarantine's Avatar
Smile Thanks alot
I tried to look for the place to post my questions,guess I messed up,sorry.I did not check the build code and the tires leave one stripe.Thanks for your help,at least I know what to look for and what to ask for.
Old 04-15-2010, 09:57 AM
Rice Killer87's Avatar
Headers/y-pipe/catback exhaust will help, do a search on gutting the air boxes (if its a TPI), and an adjustable fuel pressure regulator will really wake the car up.
Rice Killer87 is offline
Old 04-15-2010, 11:06 PM
cars3's Avatar
If your car has low miles I could see spending money on the motor for some more power. Now if your car is higher mileage, I would save my money and get a 350 and put the money in it. How ever I always love original cars with the original size motor in it. Call me crazy but when my 305 needs a rebuild in my firebird I will rebuild or replace with a 305 to keep it orignal. But on the other had it sure seems like alot of people are having alot of fun swapping engines and seeing their hard work pay off.
cars3 is offline
Old 04-16-2010, 01:15 PM
Quarantine's Avatar
Yeah
It's got 154,000 miles.Maybe I might just look for a 350 if I can find one for a good price after I get the exhaust and suspension hooked up,Thanks everyone
Old 04-16-2010, 10:54 PM
cars3's Avatar
If and when you swap engines there are alot of people on this site with alot of knowledge that can lend you a hand if you have any questions. Search around here and you can find tons of threads about engine swapping and engine transplanting.
cars3 is offline
Old 04-17-2010, 12:29 PM
Quarantine's Avatar
thanks
Thanks alot bro. this is a quick look at my project car right now. http://s944.photobucket.com/home/Qua...reak/allalbums
Old 04-17-2010, 11:38 PM
cars3's Avatar
Looks like you have a really nice car to get started with. My 305 firebird is about 40% rusted, and I don't think I can save it, so I'm just going to drive it into the ground. It's my daily driver and the salt on the roads just killed it.
cars3 is offline
Old 04-20-2010, 06:22 PM
1987IROC350's Avatar
If you ever do put an engine in it sdpc2000.com is a good place. Thats where I got my engine. So many choices. I went with the Vortec TPI engine similar to the ZZ4 GM crate.
But these are a good deal too.
http://sdpc2000.com/catalog/crate-en...p-350ho-engine
1987IROC350 is offline
Old 04-21-2010, 10:19 AM
Z28SORR's Avatar
And with this engine you won't need to do any drive train mods., though you may want to look around for a positraction rear end.
Z28SORR is offline
capebuf
01-13-2015 07:22 PM
rockync7
01-01-2015 05:10 AM
hotrod 5210
12-22-2014 07:28 AM
4586
12-06-2014 05:20 PM
Quick Reply: Help my 1986 Camaro Iroc
