convertible z28
is there any way to make a convertible top on a 87 camaro convertible come back automatically with the press of a button
Re: convertible z28
If you have the money. Hyd. pump, cyl., wires, switches, and relays. A good custom shop should be able to do this faily easily. I believe the company that 'did these tops" is still out there. May want to talk to them.
Re: convertible z28
As the long term owner of a 1988 iroc convertible I believe these cars only ever came with a manual top by ASC. It takes like 20 seconds to flip the roof closed. Why would you spend money on a power configiration? Less moving parts the better !
Re: convertible z28
Originally Posted by iroc7
(Post 6673680)
Re: convertible z28
anyways, where theres a will theres a way. I would go to your local junkyard and just pull out the assembly out of any convertible and make it work
Re: convertible z28
I think I have only been caught in the rain 4 times in 18 years. Only drive mine if its a perfect sunny day. I see what you are saying but it sounds like alot of work and butchering.
