Car wont start.. makes a dry exhaust noise, doens't sound gassy
Old 07-03-2005, 05:18 PM
  #46
85_305's Avatar
Re: Car wont start.. makes a dry exhaust noise, doens't sound gassy
*insert evil laugh here* I got it
So line up the dots, put the chain on, then put it back together and pray to the High and Mighty that was the problem?
85_305 is offline
Old 07-09-2005, 05:15 AM
  #47
fade2blk500's Avatar
Any updates?
fade2blk500 is offline
Old 07-09-2005, 11:27 AM
  #48
85_305's Avatar
No. Well, kinda (lol). The guy that was helping me, is now being a complete DICK! He put the freakin' thing in wrong (he used the stock-looking key-way) and I told him it was wrong. He got mad. I ended up working on it at 9pm night w/ my g/f's company. I put the crank-pulley puller on, and I forgot that bushing that goes in to protect the threads. Well anyways I am REALLY cranking on this thing, putting my weight into it and everything. Well, it doesn't come out so I got tell Jim. He comes out all pissed off, takes the puller off, says "where the f*ck is the bushing? Now your cranks f*cked and you need a new one!". I mashed in the first 3 or 4 levels of threading.
Well, is my crank cast-iron like I think it is? Is it possible to re-tap it? I have heard yes, and I have heard no. Any input?
Oh ya, the car is being towed to my house tomorow so I can do whatever the hell I want on it, WHEN i want!
85_305 is offline
Old 07-09-2005, 01:19 PM
  #49
Oh no man that royally sucks. You should be able to tap the threads. Hopefully you can save them. If not maybe heli coil it back to the proper size.
G-luck
Craig
Old 07-09-2005, 05:10 PM
  #50
Chris`s85Z28's Avatar
Well when I did my 1st rebuild on a 85 305 mine wouldn`t start because the rockers were to tight and it was doin what you said yours were doing So if your car doesn`t start after you get it togher try losening the rockers because your valves might be hung open like mine where. as soon as I losened all the rockers off it ran like a top , oh and I used the same timing chain as you and used the middle key way.
p.s NEVER follow instuctions that come with a new crane cam because there wrong I found out the hard way
Chris`s85Z28 is offline
Old 07-09-2005, 10:21 PM
  #51
85_305's Avatar
G-luck
Craig
Man you are making me feel a lot better about this whole thing My friend today tells me that he couldn't tap it using his carbide taps; then again he is weak. I am, not to brag, a bit on the strong side so I think if I put my mind and muscle to it I *may* be able to get it going again. Jim (my bud) also said someting about the heli-coil (pronounced Heal-A right?). So I may have to give that a try.
85_305 is offline
Old 07-09-2005, 10:23 PM
  #52
85_305's Avatar
Ya I am pretty sure mine wouldnt start because there was a total of 8* crank timing But it is together for the most part; i just have to get the crank re-tapped and slap the harmonic balancer back on
Thank you for the help though
85_305 is offline
Old 07-09-2005, 10:24 PM
  #53
85_305's Avatar
G-luck
Craig
Do you think a heli-coil would be durable enough and do you think it would fit in the crank?
85_305 is offline
Old 07-10-2005, 01:08 AM
  #54
A heli-coil should be fine as long as you can tap those threads for it. Which shouldn't be a problem. Just make sure your tap is straight as an arrow. Also be VERY patient, let us know how it goes
Craig
Old 07-10-2005, 09:45 AM
  #55
85_305's Avatar
Ugh.. how the hell am i gonna do this? Just get the tap in there and really crank on it or what?
85_305 is offline
Old 07-10-2005, 10:47 AM
  #56
http://muller.net/mullermachine/howto/insert/
Look at that for a guide. You'll have to put some muscle into it probably. Use plenty of lube and make sure you pull it out and clean it ever couple turns.
Craig
Old 07-10-2005, 11:29 AM
  #57
85_305's Avatar
So technicall, the ONLY thing that would possibly hold me back from tapping this crank would be how much pressure I can apply to the tap, right? Should I use WD40 for lube or what?
85_305 is offline
Old 07-10-2005, 11:32 AM
  #58
85_305's Avatar
Oh ya.. btw I went to try cranking it earlier It at least *sounds* like it wants to start now. It's got that sound.. that "gassy" type sound to it? It doesn't sound like somebody blowing thru a pipe anymore, lol. All I'm gonna do now is put it together, pour fuel down the carb. If that doesn't work, then I am gonna adjust the timing
85_305 is offline
Old 07-10-2005, 06:44 PM
  #59
I am a big fan of PB blaster, you can get it at napa autoparts for cheap
Old 07-10-2005, 09:45 PM
  #60
85_305's Avatar
Ya PB Blaster is GREAT.. but also expensive from what i recall. (My dad uses that stuff).
Ok.. i was looking at it today, the first prolly 4 or 5 lines worth of threading are FLAT. There is NOTHING to bite into.
What do I do? I am really panicking that I may need a new crank
How do you use a heli-coil??
85_305 is offline
Quick Reply: Car wont start.. makes a dry exhaust noise, doens't sound gassy
