Car wont start.. makes a dry exhaust noise, doens't sound gassy
#31
Re: Car wont start.. makes a dry exhaust noise, doens't sound gassy
I would guess the middle one, but if you aren't sure. Pull the number 1 plug and bump it until it blows your finger off at tdc. Whichever mark points up will be it.
#32
But if I do the middle one then the crankshaft-dot will be exactly half-way across from camshaft dot.
In order for the dots to be aligned, then I would have to put it on the first dot located at 1 o'clock.
#33
Rotate the engine till the #1 cylinder is at top dead center of the compression stroke, then set the timing chain gears to line up dot to dot using whichever keyway is in the correct position.
- Justin
- Justin
#34
^Aaaah, ok
I believe that is what was done; cyl #1 is at tdc, then I told jim we are using the key taht LINED UP, but he's like "Well unless you know for SURE, we're dead in the water".
But ok, I got it Did you get my IM last nite?
#35
Originally Posted by 85_305
^Aaaah, ok
Go get the car back together and report back ASAP
- Justin
#36
^LOL, ya, I was MORE THAN signed off by 1am. I was crazy tired yesterday. Thank you for looking though
I have to work today, so I will prolly work on it either tomorow or the day after. But I will deffinently let ya guys know what happens
#37
- Justin
- Justin
#44
Originally Posted by faded93bird
Mine is right off the cloyes instructions.
The stock looking one is the 4* retarded.
Eric
Eric
Thanks a LOT though, otherwise my car would have been retarded 4*.
Wait a minute.. i AM just lining the dots up, correct? Dot-to-dot? Or is the one I am supposed to use NOT the one that goes w/ the dot? I am thinking I go to the middle one.. as stated. First one is 4* ret, middle is stock, and last is 4* adv right?
