Cam choices for my stealthram'd 383
#48
Re: Cam choices for my stealthram'd 383
I told him that may use NO on this motor but forgot to ask if the cam will be ok for that...will it? or do cams have to be spec'd out for nitrous use?
#52
Originally Posted by Wishmaster
I asked him and he said that I can throw as much NOS to the motor as I feel comfortable with..the cam will be just fine...
#53
without the NO what kind of number you think I will put out? HP/TQ
Im not looking for a dyno queen,,I want accellaration and the guy from camshaft innovations said the cam was designed for that..
#54
#55
here's some info on my cam....can you guys explain? does this seem like it will get the job done?
Cubic Inch and Engine Type 383 CID Small Block Chevrolet
Camshaft Type Hydraulic Roller
Firing Order STD SBC
Cam Bearing STD SBC
Lobe Separation 113.5
Overlap at .050 2.2 Degrees
Camshaft Measurement Intake Exhaust
Duration at .006 281.5 286.5
Duration at .020 255.5 260.9
Duration at .050 226.0 232.1
Duration at .200 145.4 151.7
Lobe Lift .34961 .35323
Rocker Ratio 1.52 1.52
Gross Lift .531 .537
Lash HOT HYD HYD
Designed Lobe Centerline 110.9 ATDC 116.0 BTDC
Open at .050 2.1 BTDC 52.1 BBDC
Close at .050 43.9 ABDC 0.1 ATDC
Lift at Top Dead Center .0587 @ 110.9 In. Cente .0591 @ 116.0 Ex. Center
Spring Recommendation Hopefully the AFR springs work. If not, contact me for a spring kit.
Cranking Compression 189 PSI
Vacuum At Idle 15.7 Inches
Idle RPM 850 RPM
Peak Torque RPM 4400 RPM
Peak Horsepower RPM 5500 RPM
Torque Convertor Stall 4000 RPM to 4500 RPM (Flash In High Gear At 5-10 mph)
Starting Shift Point RPM 6300 RPM
Starting RPM To Cross 6600 RPM
NORES: Visit my site and read about how to install the camshaft by the Lift at TDC.
Cam Bearing STD SBC
Lash HOT HYD HYD
Idle RPM 850 RPM
#56
Cam Bearing STD SBC
Lash HOT HYD HYD
Idle RPM 850 RPM
Cam Bearing STD SBC
Lash HOT HYD HYD
Idle RPM 850 RPM
#57
That looks like a fine stealthram cam, Wishmaster.
About the only thing I see that is odd might be the flash point for that torque converter, for which I must whip out my " non-scientific rule of thumb". If you consult your torque converter manufacturers, I think you will find that they recommend a stall speed that hits at about 800 RPM below peak torque.
This recommendation appears to hit directly on peak torque for the flash point. That'll make for some monstrous torque on the launch for sure. I guess if it were me, I'd get the higher stall speed if the car is equipped with sticky tires and skinnies out front. Otherwise, I'd pick out a really good lockup converter that will stall at approximately 3600 RPM when hit with 475 ft.lb of crankshaft torque.
#58
well Im going to have to live with what I got..I cant afford a new stall right now.....I think I get one free re-stall....but then again, how do I know what the stall will stall at? Ive heard that a converter setup to stall at 3000 on a 305 might stall alot higher on a bigger cubed motor....so I guess I just have to wait and see what happened when I hit the gas
10-31-2016 11:09 AM
95chwagon
01-13-2015 09:19 PM
