85 l98 build?
Old 01-31-2019, 05:55 PM
Dylansciotti's Avatar
85 l98 build?
I just bought a 1974 Camaro with 70 front end swap it has a 85 l98 that carbed in it trying to figure out best cam and carb for it and if I'll need new heads and distributor looking for budget horsepower any advice would be greatly appreciated. Aiming for apx 400hp if possible
Dylansciotti is offline
Old 02-02-2019, 03:12 PM
Re: 85 l98 build?
You're probably going to need new heads for 400-450 HP (is that goal at the flywheel or at the rear wheels?), particularly for the 450 HP number. The cast iron GM Small-Port Vortec Bowtie heads can make that kind of power at the flywheel. If you prefer aluminum, there's the GM Fast Burn heads. Both those are tapped for both the Vortec intake manifold and the earlier SBC intake. There are other aftermarket heads available.
https://www.gmperformancemotor.com/category/SB145.html
Injuneer is offline
Old 02-02-2019, 07:32 PM
Re: 85 l98 build?
if I go 400 flywheel and did those heads would I need a better cam as well and stall? Thanks for info
Old 02-03-2019, 09:49 AM
Re: 85 l98 build?
You will need a more aggressive cam to meet your goal. Maybe you could even hit the 400 HP @ the flywheel with the base Vortec heads. You have to select the heads and cam as a package, so the duration and lift takes advantage of the head flow characteristics. I'm not up on selecting a cam for a carb setup. For the last 25 years I've been dealing with the fuel injected LT1.
Unfortunately, the number of users on this site with 3rd Gens has really declined. Seems the only active area is the few die hard LT1 users. Every once in a while a veteran 3rd Gen owners will show up and look through the posts on this particular forum.
Injuneer is offline
Cokesbody
11-17-2018 09:23 PM
lgz28
01-08-2007 01:17 PM
BMWKillR
11-13-2006 11:59 PM
harryL98
07-17-2004 12:41 AM
Zerocool
06-23-2004 02:01 PM
Quick Reply: 85 l98 build?
