1987 IROC 5.7 vbelt
Any of you guys got a belt routing diagram? I can find serpentine diagrams everywhere. I specifically need to know how to route the ps AC belt.
1 Attachment(s)
This is an old shot of a typical serpentine belt-drive setup on a late-model TPI Camaro engine that requires the use of a reverse-rotation water pump because of the belt routing. I got mines apart. :D
Attachment 23745 |
3 Attachment(s)
My bad, let me include these others as well. I noticed yours is a '87. It's gotta be one of the first two. My '88 shouldnt be different than your '87.
1988 belt routing: Attachment 23742 1989 belt routing: Attachment 23743 Smog Deleted: Attachment 23744 |
Thanks for the response. Unfortunately mine has the vbelt configuration, not the serpentine.
if you have v-belts, each accesory has it's own and the install should be fairly straight forward.
