Raising a 2012 RS - Page 2 - CamaroZ28.Com Message Board
2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
Sponsored by:
Sponsored by:
Raising a 2012 RS
Old 11-07-2018, 10:38 AM
  #16
Re: Raising a 2012 RS
Ok. I see what you're saying. No worries as I won't be going that route. The simple spacers will do the trick or if I can get a same size tire but taller, that would be the ideal solution since I'm ready for tires anyway.
Thanks, Russ
Doc C is offline
Old 11-07-2018, 10:57 AM
  #17
OP, just note that if you change the tire size, you will need to get a tuner of some sort to inform the PCM about the change. If you do not, your speedo will not be correct. This will also impact the odometer.
DrewHMS97SS is offline
Old 11-07-2018, 04:24 PM
  #18
Super Moderator
Originally Posted by Doc C View Post
So these are the oem wheels and tires.
Front: 245/45-20
Rear: 275/40-20
I just learned that 21's were available on this car which would have been great, but I have no intention of replacing my rims, especially since I have 2 sets that I switch out for Winter/Summer.
Thanks, Russ
Well, that idea doesn't work. Those are already huge tires.... 28.7" diameter. I can't find a 20" tire that is a full 1" larger diameter. About 1/2" is the largest increase I could find, and that is only a 1/4" change in ride height.
Easier to do on something on a 4th Gen, with 26.0" stock tires.
Injuneer is offline
OneFlyn95z28
Advanced Tech
10-31-2002 12:15 AM
big dave
10-25-2002 06:08 PM
96z
08-30-2002 08:19 PM
Quick Reply: Raising a 2012 RS
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
