[Brakes] How many V8 buyers will swap to V6 brakes?
There are many reasons. More sidewall generally gives better launches, whether at the track or on the street. A smaller diameter rim most likely makes the rim and tire combo lighter, and certainly reduces the moment of inertia... meaning less force is required to rotate the wheels. A larger sidewall height also makes the car ride better on rougher roads (they can be pretty lousy in the Northeast) and make you less likely to damage a tire or rim on a pothole. Smaller diameter tires are cheaper to replace. And don't dismiss the notion that some people just like the way they look better.
now if you are an autocrosser/road racer who gets a v6, wants the additional stopping power of the big brakes and doesn't mind the weight penalty, then he and the drag racer would do well to swap each others brakes.
different strokes for different folks.
carguyshu
Jan 22, 2017 11:19 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
