what kind of power will a bolton v6 make?
Re: what kind of power will a bolton v6 make?
If you decide to to go with long tubes you'll have to think about the additional cost of a tune. Every one who has installed long tubes writes that their CEL is on due high flow cats resulting the O2 sensors reading a fault. Shorties shouldn't cause the CEL but they won't make as much power. Every thing is a compromise.
Keep in mind headers (long or shorty)show the largest gains (the advertised gain) below the peak. So BBK gained 33 HP. But around 3-4K. At the top end it was closer to 12-16 HP. Shorties advertise around 20, but at peak it's closer to 5-7.
However, you don't run at peak the entire race. so you'll see those ponies in 0-60 and 1/4 mile. But you won't be able to say "312 + 33 = 345" It's more like "312 + 15 = 327."
Well the BBK LTs will still run you $800-$900 w/high flow cats, depending on if you get the ceramic coated(#40410) or 304 stainless steel(40415).
Pacesetter also offers a set LTs that are ceramic coated(#72C2232) for $380 (headers only). I'd definitely take at hard(but careful) look at these just for the fact they cost less than half of what the others run.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
