Just a girl with a fast car
Can someone tell me if these are accurate charges
street tuned/dyno $550.00
powder coat brakes $480.00
front/back brake pads, rotors, front/rear caliper seal kit $117.31
morel lifters, head bolts, crossover gasket, head gasket, coolant, lifter tray $1590.00
cam, oil pump, oil pan, timing chain $2400.00
street tuned/dyno a 2nd time $300.00
spring seals for both heads $779.00
Last edited by plumcrazy1010; Jul 9, 2020 at 02:41 PM. Reason: $117.00 is incorrect needs to be $1170.00 Forgot to ad $2500 for clean short block, hone cylinder wall torque plate
Re: Just a girl with a fast car
If those are with professional labor then they’re generally okay, maybe a little high. Are those quotes from a dealership?
How do you like getting your hands dirty? Do you have tools and space to work? You could learn some new skills and save several thousand dollars doing some of this yourself!
romoranger
Dec 6, 2008 08:07 PM
CoUnTryMuZiCZ28
Feb 11, 2004 03:19 PM
